new official firmware for 2.1
Did se release new fix or firmware version for current os? I saw some website showing minor firmware update for x8.  I still love se current os.the ui is nice,and i dont mind staying with current os(2.1). as long as its officially from se.  Thanks in advance
KrazyD
Contributor
Oh yes, I have just checked on my phone and there is no update available for me at the moment. To ensure you have the latest software Download either Sony Ericsson Update Service and or Sony Ericsson PC Companion which will make sure you are up to date.
8 REPLIES 8
KrazyD
Contributor
Hello, do you have a link to the website that you seen it on?
gwhispererz
Champion
To check for any update, just connect phone to PC Companion via USB. You should be prompted if there is. Slightly_smiling_Face
gwhispererz
Champion
My advice for you is to update phone through PC Companion or SE Update Service ONLY. Slightly_smiling_Face
KrazyD
Contributor
Thanks for the tips, ill try it, and see how,,because the firmware's release date kinda new and makes me curios.thanks moderator:-)
gwhispererz
Champion
Welcome .... It's just a 'plug' away to find out. Grinning_Face
Mhyke
anyone tried the new software?
can you post your benchmark results in Neocore and Quadrant
Thanks a lot
