Neo: Which ROM will I get in update?
owleye
I have a neo which I bought while in Hong Kong. Recently I moved to India and I think I will hold on to the Neo as I like it.
My question is that in the recent update which has 2.3.3 and the one which I want to upgrade to: will it continue to have the native chinese applications which came loaded? I want to get rid of them and use an English only ROM.
Thanks.
25 REPLIES 25
owleye
Thanks apc_use; appreciate the help.
These apps came loaded on the phone.
I do not want to add these apps but I want to remove them and hence the post.
Ok in that case, the update to Android 2.3.4 will be released soon. So usually the XDA developers will release a Global generic versiion of the firmware.
You can then download the GG version and manually update the phone..
Officially, it was announced that 2.3.4 will be released around October this year.
owleye
Thanks.
Is there anyway in which we can specify which version to install?
I am currently on 2.3.2 and would want to switch to 2.3.3 with the official generic version.
Check out this link to the various Neo firmware.
http://forum.xda-developers.com/showthread.php?t=1258723
There is a 2.3.4 Global version
http://115.com/file/e6mngpm2
http://www.megaupload.com/?d=KWNWTH47
MT15i_4.0.1.A.0.283_GLOBAL.7z
There are two versions of the 2.3.3 firmware :
http://u.115.com/file/e6docclw
http://www.megaupload.com/?d=QS4A5A7F
MT15i_4.0.A.2.368_GLOBAL.7z
http://u.115.com/file/e60c0hcd
MT15i_3.0.1.A.0.145_GLOBAL.ftf
Use the flash tool to update the firmware
owleye
Thanks apc_user
This is using the flash tool which is not the official way of updating it.This will void my warranty.
Any official way of doing this? Moderators - any answers?
Johan
Master
What's your SI number? You'll find it under the battery.
owleye
My SI number is 1246-7758
is 2.3.4 available?
Thanks.
OE
owleye
Up.
Johan - any answers please?
Johan
Master
Android 2.3.4 is not available yet for your SI. But the 2.3.3 is available and if you update the HK customization will remain, you wont get any other ROM.
owleye
Thanks Johan
When is 2.3.4 release expected for this region? Is there any official way to remove the HK customisations?
