It Doesnt Download The Update over the air and when connected to pc companion it tells me to drag down the status bar and choose mtp connection for media sync but its not there? how can i update my phone now??
you can call customer service and ask about the 2.3.3 update for your phone, since its available on other Plays but not the one from verizon
Read from page 85 here:
http://www.sonyericsson.com/cws/download/1/974/916/1301414912/R800i__UG_EN_1248-2319.2.pdf
Yea, that doesn't work.....
Which part doesn't work?
Settings > Sony Ericsson > Connectivity > Usb Connection Mode.
the Sony Ericsson Option Doesnt Show whatsoever and never has
Well Yea im the one that posted the problem so I figured id say whats wrong
Right on, yea I'm having the same problem, I posted in another thread about it....
just install Update Service on your PC and update your phone
make sure you backup everything, you can install Backup & Restore app, works with the Arc and Play
Backup & Restore App
http://talk.sonyericsson.com/message/65988#65988
just to play it safe sync your contacts w/ google if you haven't already
