Logging off the internet
Am I logging off the internet properly? As I seem to be using all my data (o2 Text and Web tariff) in about 3 weeks. I'm pressing the menu (middle) key twice to get off the internet. Is that the correct way to do this? I just wondered, as I never used to run out of data so soon with my old phone. Or is it because this is a smart phone? Do they use more data for websites?
slimshaddy
Hero
no u shud press the back button..
or u can do this..
if u are done browsing..
in the browser itself press the menu key, then select windows..
u';ll see 2 options
1 to add new and other the already opened window..
close that..there will be a "X"sign...click on it..
after that it';ll reload one page again..then press the back key..and not the menu kry ok..
4 REPLIES 4
slimshaddy
Hero
or u can do this..
u';ll see 2 options
slimshaddy
Hero
also since its a smartphone it uses more data..
there are loads of apps accessing the internet..
when u are done with the rowsing and if u use network internet
then o to settings > wireless and networks > mobile networks and uncheck enable data Slightly_smiling_Face
and if u wish to browse again..then enable it..
Thank you Slightly_smiling_Face
slimshaddy
Hero
hmm..make it answred so tht any other who may try to look for an answere can see Slightly_smiling_Face
