Korean keyboard?
Korean keyboard?
My keyboard has suddenly changed to being Korean, no matter what I do I can't change it back to English, anyone else had this problem?
gwhispererz
Champion
Hi Vwhe, are you referring to texting in your messaging app? Aren't you able to press and hold at the Write message area to select Input method?
2 REPLIES 2
gwhispererz
Champion
Uliwooly
Like gwhispererz said
go to your messaging app, open any conversation, tap on the white rectangle where you input the text, long press there, tap on Input method, now you can select a different keyboard
