Keyboard Turning
Keyboard Turning
When I turn my phone sideways my keyboard no longer turns.  Have I somehow locked it so it will not turn?
gwhispererz
Champion
Try this, Settings>Sound & display, make sure Orientation is ticked.
3 REPLIES 3
gwhispererz
Champion
Josh
Contributor
Try this, go Menu>Settings>Sound & display>and Tick/check "Orientation".
Yes!  That's it...  Thank you so much for your help~!
