keyboard layout
keyboard layout
anyone can teach me how to change back to a standard keyboard layout. i've been using my xperia play for over 2 mos. now then today suddenly the keyboard layout changed to Chinese and I cant change it because there is no option to change it.
please need help it so irritating because the layout has been changed and the space bar becomes smaller.
thanks
Uliwooly
its simple, open your messaging app -> go to any conversation -> tap on the white rectangle -> long press the white rectangle -> tap on input method and choose the default keyboard
4 REPLIES 4
Uliwooly
it worked thanks. . .
Uliwooly
anytime don't forget to backup everything on your phone just in case
Install backup & Restore app (works with arc, play, neo)?
http://www.megaupload.com/?d=I5CJUPJV
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Uliwooly
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
one last thing
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
