Hello!
I need to know if I can play the Xperia Play games on other SonyEricsson phones like Ray or neo or Arc. I am asking about the specifically designed games, for instance Crash Bandicoot or Fifa. Can such titles be bought and played on Arc or Ray or Neo?
Please reply soon.
Thank you for your time.
yes you can use the emulator on all the Androids
Mediascape was an app that was installed in the Xperia X10 which was a great idea but lagged a lot and since it was deep coded into android, it made the updates for the X10 takes SOOOOO long
Stock vanilla is Android w/o any other company adding or modifying the code, only Nexus One, Samsung Nexus S, and the new Samsung Nexus Prime
the rest of the phones have different UIs layers etc
those games are only available for the Play
https://market.android.com/details?id=com.eamobile_eu.Fifa&feature=search_result
there are playstation emulators that you can use
The link yuo attached says "Made for most smartphones" in the description. This could mean that Arc, Ray etc. are included. The best way to check is by any owner of Arc, Ray or Neo. If the Android Market does list Crash then it probably is possible. Besides i heard that even on Play you can play games using the touchscreen if you choose so. This also indicates the possibility.
I have the Arc and from this link
it is NOT compatible
But with this link it works
https://market.android.com/details?id=com.eamobile.Fifa&feature=search_result
my suggestion, is to look on your computer for the games/apps
market.android.com
Alright alright.
Had to ask one more thing, what type of games do the users of ray get to play. I mean can't they play the GameLoft or EA games other than the stupid Developer's games. This really kills Ray. Other than this Ray is far better of a smartphone. Although missing 0.7 inches, but still not bad.
if I were you, I would download an emulator to play games that aren't available on the market
OOOOOOOOOOkayyyyyyyyyyyy.
Don't mind be bothering continously. I am a newbie to Android. Used to worship Nokia so in a way was kept from the google's advancements . Anyways, the question is can I use this emulator for Ray or Arc or Neo ???????
Also if you can help me with one more thing, as I mentioned missed the developmental years of Android, so I am not aware of and need to know what is :
Mediascape
and
Stock Vanilla
Also mention which of these the following phones have :
Arc
Ray
Neo
Pro
Play
Thanks for your patience.
