Impossible to get out of korean keyboard!
Have tried settings/language& keyboard/Choose language and also set to standard keybord language.
Can not find any other way to get rid of the korean keyboard.
What shall I do ?
Jeff
Enthusiast
Create a new text message. When you see it, press and hold the empty text box, and select INPUT METHOD. This should show all the different keyboard options available.
3 REPLIES 3
Jeff
Enthusiast
Uliwooly
open your messaging app, long press on the white rectangle (input box) and tap on Input method and select any other keyboard that you prefer
Thanks for the help! Happy again!
