images do not appear in gallery
may i know y my gallery does not show all my images after i took a new photo and open my arc after shut down?
15 REPLIES 15
Apart from uliwooly's tips, you may also want to try to remove the SD card, put it in a USB card reader, insert it into a PC and copy the files over to the PC.
Then format the card. If the card is bigger than 2GB, use the FAT32 option.
Reinsert the SD card into the phone.
If the phone is able to access the SD card again, connect your phone to the PC via the USB cable and copy back the files to the SD card.
i have followed ur steps on my phone, but it still does not show the images in gallery....so what shud i do?
i try to open my gallery for few times, the oni thing the phone shows me is the file name(e.g camera, sd card, bluetooth) but does not show me the images...
try all our suggestions
Its useful but quite slow, I take a lot of pictures, often one after the other so it doesn't work for me Slightly_frowning_Face
slimshaddy
Hero
mine's working normal..
i have many images and many albums..
they load fast enough..
thx guys...i sloved my problem by using pc companion repair and update service=)
thx for all the advices...really appreciate it 😃
