I cant repair my phone
I was pulled out phone during update now i cant repair it.
SEUS shows: You all ready have latest firmware and no repair button
PC Companion shows:Unable to start all compoments
I have restarted my computer,what now?
I want my X8 back
Sorry, I don't really get you.
Anyway, un-install and re-install PC Companion and SE Update Service, then re-do the repair process again.
Just for info, phone needs to be powered off phone in order to use SE Update Service.
No repair button as i sad and did you read what i sad before,I cant turn on phone and i know phone neeed to be in flash mode
http://www.megaupload.com/?d=6XA3DQXL
Do you get it now
please help me
Did you mean that your phone update was interrupted (usb cable was pulled)? If it is, refer to this link, http://www.sonyericsson.com/cws/support/phones/detailed/upgradeinterruptedbeforetheprocessfinishedts....
PC Companion want i turn on my phone.
There is no way to repair my phone?
Follow this (from the guide).
If your phone doesn’t respond:
1.Restart the computer.
2.Connect your phone to the computer with the USB cable.
3.Start PC Companion, and select Start on the Support Zone box.
4.Click Start > Repair.
5.Perform the Android upgrade once again from the beginning.
First pc companion want phone connected by mass storage plus i does not send loader.sin so phone does not stay connected.
This all happen when i updated software (SEUS and Pc companion) old version of programs work exellent.
Please try you too repair software using pc companion.
I guess you have no choice but to send it to the nearest SE Service Center for repair.
