I cant repair may phone
I cant repair my phone Slightly_frowning_Face
I was pulled out phone during update now i cant repair it.
SEUS shows: You all ready have latest firmware and no repair button
PC Companion shows:Unable to start all compoments
I have restarted my computer,what now?
I want my X8 back
Dr_Chris
Champion
Well, if you can't use your phone at all, you will need to send it in for repair.
16 REPLIES 16
Dr_Chris
Champion
You need to use the software re-installation option with SEUS.
How i know there was before repair option now is gone Slightly_frowning_Face
Dr_Chris
Champion
Do you not see the "install" option on the bottom right of the SEUS page after you get the message that you already have the latest software?
Message you have latest software and just exit button before was repair button too now is gone soo no
Dr_Chris
Champion
gwhispererz
Champion
Hi As-mario, try with another PC/Laptop if possible. Also, make sure you have the latest version of PC Companion and SE Update Service.
Buts i cant,doesnt sony ericsson have some kind flash tool.
Please help is there any way to make seus reflash my phone. Slightly_frowning_Face
Well tryed on my friend computer he was updating his X8 then mine and usb wass pulled out,on his computer didnt work i mean no repair option but now on mine computer too.
Please help
Dr_Chris
Champion
Well SEUS is SE's flash tool, but please follow Gwhispererz's advice.
