How to silence incoming call?
Hi
How can I silence an incoming call?
RIght now all I can do is slide the red phone icon to the left and it goes into vmail.
Is there are way to just silence the call on the touch screen without answering?
Thanks
press the volume keys
11 REPLIES 11
ok, I feel dumb, haha
Thanks the volume keys worked.
I will check those apps - since this is my first smartphone w android I have to remember there is an app for everything.
Thx
No problem, make sure you backup your contacts and sms, etc just in case your phone acts up
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
Thanks uliwooly.
Since you know about these things my only concern with the apps is will they corrupt or alter the code in my mini pro sotware?
I don't see anywhere where they've been tested - I guess user reviews are the best source.
Are you using the apps that you recommend? I am not sure what is a good app and what is bad.
Thank you.
you can use your computer to look for apps on the market (its quite simple)
market.android.com
if they are on the market they are safe, you can read other user ratings
you can always uninstall the apps
on the home screen press MENU -> settings -> applications -> manage applications -> look for the app and uninstall it
and yes I do use the apps that I recomend
btw this is not my real account, I'm having problems with my original account
uliwooly
http://talk.sonyericsson.com/people/uliwooly?view=overview
you can read other posts I had
don't be afraid to install apps, that's the great thing about a smartphone
Ok thanks for the information - it all helps.
Glad I can uninstall an app - I don't want to keep doing resets on my phone.
BTW, can you recommend a good app to conserve the battery and shut down background applications?
The battery seems to last only a day.
Thx
smartphones use more battery than a regular phone, mostly because of the screen, I would recomend few things to save battery
install this app Quick Settings
https://market.android.com/details?id=com.bwx.bequick&feature=search_result
now turn off GPS, WIFI, Bluetooth, Sync (if you use twitter or fb etc and you want to keep getting updates leave it on), lower the brightness, and if you don't use 3G/Data all the time turn it off when you don't use it, this will make your battery last a lot longer
if your battery last a day, that's average with smartphones
