How to save installed apps on SD card?
Can anyone tell me how to save installed apps on SD card rather than phone memory?
Uliwooly
9 REPLIES 9
Dr_Chris
Champion
This is only possible on Android 2.2 and higher.
Thanks Dr. Chris. Is it possible to upgrade to 2.2 version now?
Uliwooly
not true, there's a way around it to install apps2SD
Uliwooly
Dr_Chris
Champion
Yes, but doesn't that involve rooting the phone first?
Hi uliwooly. Thanks. But it's kinda complicated. Does it actually work?
Hi again Dr_ Chris. What does it mean by rooting phone? I'm kinda slow with this things. :smileyblush:
Dr_Chris
Champion
Uliwooly
it works, it seems complicated but its not that complicated, just follow the steps
