Hey my Touch Screen Stopped Working
Hey Guys,
Today morning, suddenly my NEO was really HOT, near the camera, and my touch screen was not working. I could not switch it off since the touch screen was not operating so had to pull the battery out. I let it cool down and then restarted it again. The apps everything seem to work fine, since when i press the headset button the music plays, the touch screen is not working.
Please HELPppppppppppppppp
Sam
Legend
Legend
Basicly this means that there was a hardware issue with the main board and that they have replaced it.
16 REPLIES 16
Uliwooly
How to execute it on my NEO. Since i am unable to access any internal files Crying_Face
Uliwooly
you have to do this on your PC
Uliwooly
download and install Update Service on your computer
run it select your phone, and wait for it to ask you to connect your phone on FLASH MODE
Flash Mode = turn off yor phone, take out the battery, put it back in, press and hold the BACK button, while still holding the back button connect the USB cable, keep holding the back button untill Update Service tells you otherwise
But since this is a Hardware problem do you think, this would make any difference??
It states that,
"Your Phone already has the latest software", do you think i should reinstall the software??
Uliwooly
yes, you should reinstall it
Uliwooly
well at this point you don't know if its 1) software 2) hardware 3) software & hardware issue, that's why if you repair your software/firmware and the problem persist you know for sure its your digitizer
Nope NO updates working had to return my Xperia NEO for repairs.
Will be getting it back NEW or repaired
