hello, i have downloaded a few games at the same time wit my arc, after i finished download, i cannot find whr is it..,but i try one more time on downloading one game only and after finis download the game automatically install in my phone...and i can play the game...
so may i know whr are the games store after i download (regarding on this problem: i have downloaded a few games at the same time wit my arc, after i finished download, i cannot find whr is it?)
Any installed games should appear in the main menu of the handset ready for use after installation. If they are not then there are two things you may wish to try:
so if i use this method "Main Menu > Settings > Applications > Manage Applications > Menu Button > Filter > All > Market > Uninstall Updates", after i clicked uninstall updates, wat will happen?
All it will do is uninstall any updates to the Market application itself so no data will be lost. The reason I would get you to do this is that sometimes an update to the Market may not apply correctly causing an error in its functionality.
so if i use this method then the game juz now i successfully downloaded will be cleared too?
No this will not have any effect on this content, only a soft reset to the Market application itself.
ok...thx....i did the first method, but the phone din show anything....btw, thx ya...i will try few times abt dl few games at the same time, if same problem appears oso i will use the method of repairing thru pc companion...thx....
No problem, do let us know how you go with this.
