ive changed my language to chinese by mistake and dont know how to change it back!!
Goto Settings (hammer & spanner icon)>Language & keyboard(11th option>Select Locale (1st option), you should be able settle the rest from here. Good luck.
thanx loads!!!!!
Welcome, have a closer watch on those fingers. :smileywink:.
