can't change notification sound
I tried to change the notification sound, but it's always the default sound even if the phone says that it's changed...  why?
I have to wait for the firmware update to 4.0.1... (in Italy we don't have this firmware...)?
slimshaddy
Hero
u can do this..
go to settings > sound > notification ringtone
and select
or
go to messaging app..
press the menu button select settings
then select notification tone..
select ur sound..
see if this helps..
4 REPLIES 4
slimshaddy
Hero
how are u changing the notification sound ??
slimshaddy
Hero
u can do this..
and select
or
select ur sound..
see if this helps..
it's strange because in settings > sound > notification ringtone didn't work, instead with messaging app I succeeded to change the sound!  thanks a lot Slightly_smiling_Face
slimshaddy
Hero
hmm Slightly_smiling_Face
i dont know why this happens....
bug maybe..
