I recently replaced my old cellphone with an Xperia Ray so I'm new to use smartphones.
I found my SIM card was of an old model so I had to replaced it aswell to be able to use internet via my provider.
I copied all my contacts from my old SIM to my new phone and worked flawless but now i can't back them up.
I tried with PCCompanion (?) but there were no options to backup my contacts to my computer. (Stupid)
Neither can I get the sync to work so save them at Google or Ericsson.
Am I doing something wrong here? Anyone have any suggestions?
TA
-Stefan
go to contacts..press the menu button..
see if you get option o backup contacts..you must..
also download myphoneexplorer from here..
http://www.fjsoft.at/en/downloads.php
and for your phone..
https://market.android.com/details?id=com.fjsoft.myphoneexplorer.client&hl=en
Oh, how could I miss that?
Thank you for your quick reply.
I will check out myphoneexplorer too. Thanks for the tips.
aah it happens..sometimes we cant think of the most easiest answers it happens 😉
enjoy your smartphone 😉
