After Firmware upgrade for my Hazel, my widgets shortcut on mobile home page is missing
Hi guys,
            After Firmware upgrade my Hazel, my widgets shortcut on mobile home page is missing
can you please suggest what to do?
Thank you
Regards,
Abhi
Message was edited by: abhi.khare
Sam
Legend
Legend
Please follow the link bellow, install and run the software following the instructions it provides:
http://www.sonyericsson.com/cws/support/mobilephones/downloads/subject/updateservice/cedar?cc=au&lc=...
7 REPLIES 7
Sam
Legend
Legend
Even if it says that the software is up to date I would still advise continuing with reloading the firmware as this will likely resolve the issue.
How do i go about doing the firmware update?
Sam
Legend
Legend
Thanks for the tips...I have managed to upgrade the firmware...now I have to monitor the phone to see the performance.
One more thing, after the upgrade I am not able to see the shorcut for my widgets on the mobile home page.
Did some amount of googling and found the resolution...need to reboot and remove and re-insert the battery and wow...it worked (reminds me of some popular OS for desktops :smileywink::smileylaugh::smileyhappy:
Sam
Legend
Legend
Sorry for the delay, I was away for the weekend, glad to see this has work out though Slightly_smiling_Face
