12 Key keyboard
Can anyone tell me how to use the 12 key keyboard for SMS input on the Xperia Play?
Thanks
James
Uliwooly
just download this keyboard from the market
https://market.android.com/details?id=com.betterandroid.betterkeyboard8&feature=search_result
once you do so go to settings -> language & keyboard -> check the better keyboard -> tap OK
open your messaging app -> tap on the white box as if you were to type a txt -> long press the white box -> tap on Input method -> select better keyboard
1 REPLY 1
Uliwooly
