My xperia m4 just stopped working. It will not turn on or charge. Can anyone help please
Hi @Dh_, sorry to hear about your device.
You mention that you tried holding the power button for two minutes, have you done the same with the OFF button that you can access if you open up the cover the the memory card slot? If you haven't done that, please do so.
Let me know how it goes!
Yes, I have. I now have a replacement phone (long awaited to be honest) so I'm not desperate, but I would like to have it as a backup .
my xperia m4 aqua dual is not turning on and don't know whether it is charging or not.i tried the tips you given in troubleshooting but it doesn't work plz help me out
@Dh_, thank you for this information.
The next step would be to try and perform a software repair using Xperia Companion. This will reinstall the latest available software in the device, but do note that all data stored on the internal storage will be deleted in this process.
If you are still not able to power it on or charge it, the device will need to be examined at an authorized service centre as the software repair is the last step that you can do on your own. Your Local support team will assist you further with arranging a repair, so get in touch with them.
@pvmanik2, sorry to hear about this.
If you have tried all the troubleshooting in this thread, your device will need to be sent/handed in at an authorized service centre so a trained technician can have a look at your device. Your Local support team will assist you further with this matter and they will be able to inform you if there are any service centres in your area that you can visit.
Keep me posted!
My phone has been off for around a couple of months now and i have been trying to turn it on,but when i try to plug in the charging cable the phone turns on and immideatly shuts off. so the red light starts to glow then the screen turns on and it shuts off and it in a loop.HELP PLEASE
Hi @Natan1, sorry to hear about this.
Have you had the chance to try any of the troubleshooting that I have previously posted in this thread? If you haven't done so, please do so and let me know how it went!
Yes i tried every single solution and it doesent work the off button holding the volume rockers and the power button nothing works
@Natan1, you can try performing a software repair using Xperia Companion if you haven't done that already. Do note that this will delete all data on the internal storage.
If you still aren't able to power it on, the device will need to be examined at an authorized service centre and your Local support team will assist you further with this.
Keep me posted!
