unfortunately settings has stopped working on Sony M5 Dual E5663
9553314944
How to slove problem
1 REPLY 1
Jonas
Master
Hi @9553314944, sorry to hear about this. Slightly_frowning_Face
Can you try and restart your device in safe mode and see if you are able to access the Settings menu in here? If you are able to do so, go to Settings > Apps > tap the three dots in the top right corner > Show system > scroll down and find "Settings" > Storage > Clear data > OK (while the device is still rebooted in safe mode).
Let me know how it goes!
