unfortunately settings has stopped working on Sony M5 Dual E5663
Pra123-
Whenever I am trying to chnage my lock screen. I am getting error "setting has stopped working" and I am not able to change my screen lock.
I have updated my phone to Android 6.
Please help
39 REPLIES 39
Jake-SonyXperia
Champion
Hi @Anand_28,
This is unfortunate, let us see if we can help.
You could attempt clearing the settings apps data.
Menu > Settings > Apps > Settings > Clear Data
Let us know how you get on.
Ronakca_21
When I am going to change screen lock ๐Ÿ” it shows unfortunately settings has stopped.
Factory ๐Ÿญ data reset & Settings > Apps > [menu] > Show system > Settings > Storage > Clear storage do but not working that.
Software version is up to date.
Service center software update n format it.
Yet problem is not solve.
Wat to do now...
2507
Unfortunately setttin has stopped
andkrist76
hi all, i also having same problem. i try all of any suggest from forum, and android forum. it's seem to be a bug problem.
as i buy phone 1st time T15, Vivaz, etc from sony.. all is ok, excepted  after sony mobile..
now i only left sony mobile z, m5 dual, vivaz.
and now i buy new " not from " SONY " again.. sorry sony, cause your respect to customer is too weak..
Helloitsme
I just wanted to change my pattern into a new one. The system said: unfortunately, setting has stopped.
I thought the problem would end if I install the new update. But no. I've got a M5. May someone could help me? Thank you in advance.
aliVGN
unfortunately the settings stopped when I wanted to use the screen lock, what should I do
suhana1
I am facing the same issue...I am unable to open setting app ..how will clear data or format this phone
Please Help me
sammy81
I am having the Same problem.  even I cannot open a single option inside setting.
Masanirajput
Help
Uliwooly
@Masanirajput
Its really difficult to "Help" you if the only thing that you've posted it's that, Help.
