Tiba-tiba ada notif "sistem IU terhenti" layar kedip-kedip dengan waran layar warna-warni...kenapa yaa ?
Suddenly there is a notif "UI system stopped" screen flickering with colorful screen warrants ... why?
gt
Same problem here.
tienes que detener las aplicaciones que instalaste al iniciar el problema o antes y borrar algunas de Sony y si quieres la vuelves a instalar. Si persiste el problema tienes que volver a borrar esa apk que instalaste y te genera problemas. Muy probable que sea Facebook aplicativo el que genera el problema o Chrome que consume recursos innecesarios y hay uno mejor que se llama Ópera !!
Espero les sirva mucho!!
Emanuel.
you have to stop the applications that you installed when you started the problem or before and delete some of Sony and if you want to reinstall it. If the problem persists you have to delete that apk that you installed and generate problems. It is very likely that Facebook is the application that generates the problem or Chrome that consumes unnecessary resources and there is a better one called Opera!
I hope you serve them a lot !!
Emanuel.
gt
