SD card won't stay inside the slot
Mariagcpp
MySD card won't stay inside slot, only after close the slot. It worked fine but once the phone didn't restart so I opened the slot to press "off" and when I opened the memory card jumped out too, I tried to fix it but it won't stay in, then I got bother so I closed the slot, and it works fine but it's annoying, can anyone help me. Cuz after reading some posts I'm afraid to send it to repair.
Help please
3 REPLIES 3
ChloeS
Contributor
Hi @Mariagcpp,
Welcome to the community!
Sorry to hear about that, it must be frustrating Slightly_frowning_Face
In this case as this is a hardware issue with the phone you would need to contact Local support to have a repair arranged.
Mwara
It took me ages to get the piece of paper out of the slot. What a stupid idea putting bits of paper in a tiny slot. My sd card still wont go in. Probably more paper down below.
dandiane
Bonjour
J'ai le même problème, mais c'est un smartphone en cadeau ?
Comme solution : j'ai avec un scotch, empeché la carte sd de sortir et cela fonctionne ?
Dandiane
Hello
I have the same problem, but it's a smartphone as a gift?
As a solution: I have a tape, prevented the SD card from going out and it works?
Dandiane
gt
