Ring volume
Nuu59
Ring volume
Ring volume
When I get called the ringtone is too little. I checked everything I know.
Also alarm clock plan.
Volume Suoneria
Quando ricevo chiamata la suoneria è troppo poca. Ho controllato tutto ciò che so'.
Anche allarme sveglia piano.
2 REPLIES 2
Uliwooly
@Nuu59
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Could you test the loud speaker?
Settings > About phone > Diagnostics > Test
Oreo
Settings > Support > Tests
Linda1701
Depending on the type of ringtone. You can try other ringtones ( Top Ringetoner download )
