Marsmallow 6.0 and SD card as internal storage
RoarS
Regarding this article this should work, but I can not get it to work. Anyone that have tips?
http://www.xperiablog.net/2016/03/10/how-important-is-adoptable-storage-to-you-in-android-marshmallo...
124 REPLIES 124
OSIRIS07
Thatcher was cynicism, a rebound to people who advise people with 8Gb M4 to buy the dual version.
I am not stupid, I know I won't get a refund. I was ignorant, but that can not be a reason for refund.
That said, I do not think I will buy Sony in the future anymore. Not that I am displeased with the devices (I had the Go, then the M4), but the support lags, and lacks. The devices them selve are nothing short of everything I need /want.
Shen02
@OSIRIS07
M4 Aqua have many variants model only E2306 & E2363 is 16gb but not all regions / country available.
You can enable adoptable storage by yourself just watch YouTube tutorial how to enable adoptable storage for Xperia M4 Aqua.
But make sure you buy high quality class and high speed SD card.
Hope this will help and solve your insufficient storage.
Fill_Said
Why not switch off the Sony bloatware and make it deletable? The people decided to choose Sony hardware for quality, price, whatever. Let people decide what software they want to use instead of forcing the bloatware that people do not want to use and takes lots of space. What you are actually doing is forcing people to choose not to but Sony which is determental to the company. It maybe the case that creating a 8GB smartphone phone and loading with undeletable software is for a smartphone "not fit for purpose".
flying_smartpho
This solution is too easy and useful, so it will not happen. Zipper-mouth_Face
Frikk
Hello.
This has been a topic since release.
Since programs like facebook, messenger  etc are increasing in size, I actually have to disable a lot of the pre installed programs that i have no use for just to get them working.  Most of them in which when possible are stored on the SD card.
BUT, will sony open up for merging the memory so SD card will be available for the internal flash ram ?
Best regards
NeoBeum
Enthusiast
I've been rooting my phones since 2.1 to do this... I don't know why Google never made an easier approach to doing this or why OEM like to push apps into the ROM
Didrik
Enthusiast
Hi @Frikk,
Welcome to the community!
I'm afraid that this will not be possible. You can use your SD-card as portable storage in your phone in order to store certain apps, photos and other media. The option to format an SD-card as internal storage was removed as it impacted software encoding and quality.
I'm sorry for any trouble that this may cause, I can forward whatever feedback you may have about this.
Frikk
If you root your phone it is possible, and it was running nice for me in android 5.
The problems is that I only can download 4-5 apps before the memory is full After flashing my phone and after storing them at the SD card. Even the apps were slower running them from Andoid 5, it was working.
Citizen_Crazed
@Didrik,
I will firstly echo the comments of others here who have lamented the lack of adoptable storage on the M4 - given its paltry onboard memory. If Sony can be persuaded to support this feature, it will definitely influence the purchase of my next phone positively.
I will also add that your comment about 'certain' apps being storable on the SD card is more than slightly ironic. I've recently bought an RM-X7BT bluetooth remote for the car - and it works very nicely with the M4. However, why on earth is the 250MB+ of voice samples included in its app not storable on SD Card? Again, given how storage limited the phone is, that's taking the proverbial.
If you can feed this back to the app development team on the X7BT, that would be much appreciated.
Lak_vin
I had a problem in my camera after i exposed it to water. And i had to replace the both cameras. Now i have my phone updated to Android Marshmallow. All worked good for few days and now the camera app showing an error which says " Camera is opended by another app, please close it and try again " but i reset the phone again & tried, but it won't work. Please someone help me to fix it. 😞
