he cambiado la batería después de un largo periodo sin uso, pero ahora solo parpadea una luz roja y no enciende, ni vibra ni nada. Si alguien sabe qué significa. Gracias
I have changed the battery after a long period without use, but now only one red light flashes and it does not turn on, vibrate or anything. If someone knows what it means. Thank you
gt
make sure that the litttle orange-black'' thing'' from above the battery is put on corectly.Press the black ''thing'' until you feel a click.Good luck.
Si, creo que eso esta bien, sino no se encenderia la luz roja. Creo que voy a cambiar la placa base y ya que estoy el conector de la bateria por si acaso. Sino es de una cosa sera de la otra.
Yes, I think that's fine, otherwise the red light does not turn on. I think I'm going to change the motherboard and since I'm the battery connector just in case. If it is of one thing, it will be of the other.
gt
