I replaced the battery but it does not turn on
Unhealthy
he cambiado la batería después de un largo periodo sin uso, pero ahora solo parpadea una luz roja y no enciende, ni vibra ni nada. Si alguien sabe qué significa. Gracias
I have changed the battery after a long period without use, but now only one red light flashes and it does not turn on, vibrate or anything. If someone knows what it means. Thank you
gt
2 REPLIES 2
SuccesXSabi
make sure that the litttle orange-black'' thing'' from above the battery is put on corectly.Press the black ''thing'' until you feel a click.Good luck.
Unhealthy
Si, creo que eso esta bien, sino no se encenderia la luz roja. Creo que voy a cambiar la placa base y ya que estoy el conector de la bateria por si acaso. Sino es de una cosa sera de la otra.
Yes, I think that's fine, otherwise the red light does not turn on. I think I'm going to change the motherboard and since I'm the battery connector just in case. If it is of one thing, it will be of the other.
gt
