How do I free up internal storage space?
Marishnic
I cannot load the apps that I want and need onto my phone.
At the moment, 7.38GB of the 8GB internal storage space is used. There are a number of Pre loaded Apps that I do not need or want.
When I disable some apps (for example Amazon). They still hog internal storage space.
Frustratingly, I have 14.83GB of space avaliable on the SD card. However hard I try, I cannot find a way either to delete unwanted apps or transfer them to the SD card.
Please, can anyone help?
2 REPLIES 2
ree13
Go to settings then storage at the bottom of pages it says transfer to SD select it calulates & ticks items
you select transfer
you can also uninstall updates in apps you don't use and stop auto updates
Pahncat
Ensure you've backed up everything then do a factory reset/reboot. The process cleared up 8.2 GB of my internal storage.
