Hi everybody!
I'm in a bad situation, just got my new phone but I've already forgot the pattern. Is every hope gone...?
Try performing a system repair using PC Companion - This will factory reset your phone and erase all data
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the on screen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
Hi!
The problem is, I haven't connected the phone with PC Companion.
That's ok just install the program and follow my guide
Thank you, but I don't need any more help. My Xperia works properly again.
Please note this does not work.
There is no option to select my phone or I am not sure where to select? I only see the following:
- Play sound
- Secure devise
- Erase devise
