Does M5 have VoLTE Support?
Pra123-
Does Sony M5 support volte and what is the benefit of volte.
37 REPLIES 37
Xpm51
How to enable 4g volt in Xperia m5.
Didrik
Enthusiast
Hi @Xpm51!
I merged your thread with this one as it was the same question. Check out the suggestions here and let me know if there's anything else!
kashyappotu
Is it the carrier or the manufacturer who make the phone 4G VoLTE enabled? I think it's the manufacturer as someone told me that it's a feature of the phone. And may I know why Sony Xperia z5 is 4G VoLTE enabled but not Sony Xperia M5 dual? Please do something to make Sony Xperia M5 dual VoLTE supported.
Ravikumar2
I talk to jio service provider they said your phone should be volte supported when I check out does my Soc support volte feature by dialing *#*#4636#*#* it shows turn off volte provisioned flag so if Sony roll out update then I it will start Supporting volte
Ravikumar2
Mediatek x10 supports volte feature why dont you roll out software update for volte support in Sony Xperia m5 dual. In India so user can use jio 4g
Emir1
Hero
Hi @Ravikumar2, as I mentioned previously in the thread I'm afraid that this feature is dependant on the operator. Just to clarify what I meant, the operator has to enable the feature for your specific device. My recommendation is that you get in touch with your specific operator to see if they plan to enable VoLTE for your specific device and their operator branding.
I hope that clears things up! smile happy
Sen20
Any updates for VoLTE in M5 Dual
Emir1
Hero
Hello everyone, I have received some additional information regarding the VoLTE feature. I am sorry to say that our Sony Xperia M5 model does not support VoLTE, according to the information that I have available. However, I would thank you all for the shown interest in such a feature and I will make sure to forward it internally as user feedback!
Sen20
Any updates available to convert it into VoLTE. I mean any software update. Because I have here some brand have some software updates for there devices and now device are working as VoLTE.
Sen20
It not depends on operator is on the manufacturer.And is only the software issue. And Z5 has VoLTE support then why not M5?
