Deactivate zoom with triple tap
Ellasay
Hey,
when I triple tap on the touchscreen my phone zooms in. I would like to deactivate that, because I don't need it and it ennerves me..
I found similar posts for other phones, but I can't find the right description for the M2.
Hope you can help me...
profile.country.RO.title
_alexdon_
Settings-acccesibility-magnification gestures.
alexdon
7 REPLIES 7
_alexdon_
alexdon
Ellasay
But at settings I can't find the option accessibility. Where is it?
_alexdon_
Scroll down down,way down.Almost at the bottom.
alexdon
Ellasay
Okay, that's embarrasing.
Found it.
Thanks a lot Slightly_smiling_Face
_alexdon_
Don't worry,you are welcome.
alexdon
Chinita083
Thank you so much. Been searching for the answer since yesterday. Thanks!
_alexdon_
@Chinita083 glad this community can help out.
alexdon
