I'm happy to hear that @schkr! I have also forwarded this internally for investigation so in either case we are looking in to it.
Hi @Georges98 and @Ozgarb, I can see that clearing data for the clock app and setting the time manually seems to have helped, could you try to see if it makes a difference for you as well? You can find instructions on how to do so in my previous post here.
Let me know if it worked for you guys as well!
Emir, I clear the clock data
With manual mode alarm clock is fine but with auto mode alarm did not ring as it should
So , Its a bug ...
I will choose manual mode for a while , but the company must fix that bug ....
I am happy to hear that it works with the solution I provided! In addition, I will make sure to forward the automatic setting feedback internally as user feedback.
Will SONY fix that problem ?
I understand your concern, @Georges98, but I'm afraid that I do not have any further information regarding this at this moment.
does this happen when you are on safe mode?
since you recently updated your device you can try to perform software repair using Xperia Companion
Hey @SW6, I am sorry to hear that.
I posted a reply in this thread previously which seemed to help users experiencing the same behaviour, could you try to see if it helps in your case ass well?
You can find the post by clicking here!
Let me know how it went!
