Battery problem after update
vinay1
I bought xperia L recently and updated to 4.2.2 and expereincing serious battery drain.
Previously i was uisng xperia Miro and satisfied with the battery performance.
But in xperia L batttery is getting drain and i am not using phone fully and once in a day i need to charge 2times to keep my xperia L alive.
My usage will be of chatting in watss app and facebook that to not continuosly, please if any one faced this problem help me out.
37 REPLIES 37
TyDrace
I'm not using any battery savers (save for those of the Xperia self such as Stamina Mode) and also no task killers. I'll try a software repair.
profile.country.RO.title
_alexdon_
Go for it,keep us updated.Backup your data before.
alexdon
Devastator
Hm, I must have missed this thread, when starting the other, with the same issue:
http://talk.sonymobile.com/t5/Xperia-L/Sony-Xperia-L-battery-drain-issue-with-some-research-done/m-p...
Looks like it is pretty common issue...
Some people suggest disabling data dormancy, but this requires root acces, and I do not want to do that.
TyDrace
I've done the Software Repair and with Stamina Mode, Low Battery Mode and Location-Based Wi-Fi on it now says it has a standby time of over 3 days. It's still installing the apps, but time will tell if it works or not.
_alexdon_
Ok,we will wait for your answer.
alexdon
TyDrace
Phone has been on for 10h 6m, on 41%. It is currently awake for 7h 35m and entered deep sleep for 29m. After about 6 hours of sleep last night, it dropped from 94% to 71%, and using it on the way to work for little ove ran hour it dropped 30%. I installed an app called Wakelock Detector and it says, agreeing with the power management battery option, that the app Phone is the biggest offender and keeps my phone awake for 7 hours. It alone has drained 39% of the battery so far.
It's "slightly" better, as now I'll at least believe it'll last 16 hours, but it's nothing compared to the 40 hours, with extensive usage, of pre-update.
Any further advice or should I wait it out for a week?
_alexdon_
I think you should wait a couple of days.Restart the phone often(every day).See if this improves.
alexdon
manishkumar7874
really???
