I watched my first Lovefilm stream to a BDP-S570 last night. Most of the time the quality was quite good but the picture pixellated during action sequences.
I run the system over wifi to an Orange 'Livebox'. Would I be better using a hard wired connection or are there system tweaks which would help?
Message was edited by: Catmambo
Wired>Wireless More stable, secure and easy to use. Either that or get a set of homeplugs which can do the same thing. Very few system tweaks you can make to be honest,
Thanks
