reactarail
UBP-X700
As any one been able to connect this DVD player to a Sky sound box if so can you let me know how?
Thanks K
6 REPLIES 6
EdwinaU
Moderator
Hi there,
Welcome to the community.
We will look into this and get back to you as soon as we can.
Meanwhile, another member may be able to offer some advice.
Best wishes,
Ed
The_Black_Rose
Specialist
Hi Reactarail,
I believe you just need a HDMI cable. I've just had a look into the manual and I found a connection guide on page 12, you can access it through this link: http://bit.ly/2x8Nzsz.
Cheers,
The_Black_Rose
reactarail
That's correct but I don't have a spare HDMI socket on my Sky sound box to
take one, only have optical socket free.
The_Black_Rose
Specialist
Hi reactarail,
I don't think this player can be connected via optical. It doesn't have an audio in/out jack.
Cheers,
The_Black_Rose
reactarail
Hi could I get an optical adapter so I can come out of the DVD with HMDI
and go into the Sky sound box with optical?
The_Black_Rose
Specialist
Hi Reactarail,
I don't think so. Usually manufacturers can't guarantee that the adaptors would work.
Cheers,
The_Black_Rose
