'There is no title' problem
I have a RDR-HX750 DVR DVD RECORDER. I have a few recordings made to DVD that now can't play as a message comes up 'There is no title'. All the recordings had previously been viewable. Any solutions please?
Hi dustnbones,
Welcome to the community.
I’m just looking into this for you and will get back to you shortly.
Thanks,
Pascale
Hi dustnbones,
This sounds strange. Have you tried to play the DVDs on a different player to check if the issue is with the player or the discs?
If they worked, may try resetting the player. I've checked the manual and could find reset instructions on page 135. You can also get the manual from here: https://bit.ly/2IaysGa
Hope this helps,
Almou_10
Ok thanks. Will look into reset as discs play on my brothers DVD player. Get back to you later.
