Sony RDR-GX350 copied DVD-R disc not recognised anywhere else
ainsleyk
Hello,
I bought a Sony RDR-GX350 22W HDMI 1080p DVD Recorder specifically to copy a Sky+ HD recording where I was on a TV quiz show onto a disc with the end goal of getting an MP4 copy to keep and share with my friend who I went on the show with.
I used Verbatim DVD-R discs and successfully copied the recording onto the discs which play back fine through the Sony DVD Recorder.
I purchased a Kadlun External Disk Reader with the aim of copying the digital version of the file onto my laptop. Unfortunately, I can't get the disc to be recognised there or in an Xbox One X. I am in communication with Kadlun to try and troubleshoot it with their measures, no luck so far. A purchased film DVD is recognised in it so the external drive isn't the issue.
I wondered if anyone more technically informed than me knows if for some reason the disc is only formatted to work in the Sony RDR-GX350 and will never be able to be read anywhere else or if there is a solution where I can get it to be read and copy the root file and get an MP4 or similar copy?
Appreciate any help on the matter
2 ACCEPTED SOLUTIONS
LightFoot
Specialist
@ainsleyk wrote:
Do you know if there are additional steps I can take to finalise it now? Kind regards
Hi @ainsleyk   Hopefully, you will find everything you need to know in the manual. Page 37/38.
https://www.sony.com/electronics/support/res/manuals/3113/31137591M.pdf
rooobb
@ainsleyk as per the manual @LightFoot  kindly linked above, it is not a step asked by the recorder when recording the video, since you may want to add other videos to the same disk. Afterward you can go to the disk setup menu and finalize it so the it creates a DVD-like menu and structure and the disk can be played back on any other DVD player.
If you have still access to it, sure you can finalise the disk now
10 REPLIES 10
rooobb
The discs on Sony recorder should be finalized on the recorder itself in order to be read on other devices... Did you finalize the disk?
LightFoot
Specialist
Hi @ainsleyk   I have to agree with @rooobb . You have to finalise the disc, it takes me back to the last century with my old Sony DVD recorder.
ainsleyk
Hi @rooobb really appreciate the response. I can't specifically remember on the finalisation front, I copied the disk Christmas 2023. I followed all the on screen prompts at the time to my knowledge. Do you know if it would have been an extra on screen prompt? I can't see why I would have not finalised at the time. I still retain access to the Sony recorder. Do you know if there are additional steps I can take to finalise it now? Kind regards
ainsleyk
Hi @LightFoot, really appreciate the response. Tell me about it, it's a one off task for me too and the only way to get anything off a Sky HD Box so working through it as best I can. I can't specifically remember on the finalisation front, I copied the disk Christmas 2023. I followed all the on screen prompts at the time to my knowledge. Do you know if it would have been an extra on screen prompt? I can't see why I would have not finalised the disc at the time and passed up on the option. I still retain access to the Sony recorder. Do you know if there are additional steps I can take to finalise it now? Kind regards
LightFoot
Specialist
rooobb
ainsleyk
Brilliant, thank you so much! I'm in process of obtaining a remote to go with the DVD Recorder so I can do the disk finalisation outlined in the manual. Really appreciate you taking the time to respond.
ainsleyk
ainsleyk
Hi again,
Bought a universal remote and formatted 2 out of the 3 discs, success on those! Thank you again for your help.
The third disc I recorded, to my surprise, won't load or play anything and after Loading for a while the error message, 'Cannot format' with an empty timestamp line shows, so it won't play back the recording that I saved from the Sky+HD box (different house). Doesn't play anything on an Xbox One, either.
I'm pretty sure at the time I checked the recording after recording and it had worked on DVD-Recorder played back. I can't see anything in the manual for the error and can't finalise the disc or see any content on it.
Do you think my best course of action is to re-record from the Sky+HD box onto the DVD-R, then this time I can finalise it there and then? Thanks in advance for any advice :slight_smile:
