Sony BDC-S1000 and Ultraviolet/Flixter
Dave2078
Hello,
I'm looking for a little help.
I have bought a Sony BDC-S1000 Blu-Ray player and I would like to play my Ultraviolet/Flixter movies on it.
I cannot find a way to do it. There is a Flixter app on the device but you can only watch trailers.
There is mention of a Vudu app but its not on my device.
Does anyone have any ideas?
Thanks in advance for your help
Anonymous
Hi there
Flixster is the app you are looking for (I believe).  A couple of reference links for you:
Edit: See Catmambos response to this post : HERE
3 REPLIES 3
Anonymous
Hi there
Dave2078
Thanks for taking the time to have a look for me,
I'm sure its the Flixter app i need too, however there is no option to log into my account from it. Maybe this will be a future update.
So Catmambos is saying that they will be looking into in the future, hope it will be sooner rather than later:smileyrolleyes:
miroperdl
  I have the same problem with a new BDP S790 Blu-Ray player. The Flixster application has been restricted so all it can do is show trailers - not sure what the point of that is.
I then looked for other apps such as Vudu but  they're not available. Some of the other apps including Sony Entertainment Television don't work at all.
Pretty poor.
