Is BDV E-300 upgradable to a display 3D and can it used to covert KDL 803u to an internet TV?
profile.country.en_GB.title
sigmore
Is BDV E-300 upgradable to display 3D and can it be used to convert KDL HX803u to an internet TV?
Catmambo
Contributor
Unless the device is marked as 3D ready, you can't update/flash them later to make them 3D compatible I'm afraid.
Thanks
1 REPLY 1
Catmambo
Contributor
Thanks
