infared extender
profile.country.en_GB.title
assimb
infared extender
Hi
I have a sony BDV NF620 blu ray system and i have it placed inside a draw in my tv unit & i need a infared extender wire to use the remote without having to leave the draw open.
Do sony produce any such wire & does anyone know if i can get someting the will do the trick.
thanks
assim
Anonymous
Hi there
Ive not owned one of these (or others for that matter) - but I think it works this way:
- You have a cable/lead (IR Emitter) that is placed infront of the IR port on the bluray player and then you physically connect that to the main IR unit on display
If you have one with an external box (control unit) you will connect it to the mains power supply:
ie.
www.amazon.co.uk/Marmitek-Invisible-Control-Infrared-Extender/dp/B000GIXHGA/
I think this one is more designed for multiple devices (ie Bluray, DVD, AV Receiver, PS3 etc)
Or you have single ones (you will need a USB connection - for power), such as:
http://www.amazon.co.uk/Infrared-Control-Receiver-Emitter-Adaptor/dp/B00FPI18C6/
If you read the reviews on Amazon, you kinda get the idea/general gist of how it connects and works.
Hope this helps anyhow
4 REPLIES 4
Anonymous
Hey there
Plenty on Amazon
Such as:
Just read the description and reviews of the product to ensure that it does what you require.
assimb
hi
thanks for the info reaaly appriciate that, do you know what sort of connection these devices use as its not clear from the description as i think i would need a usb one for my player.
thanks
assim
Anonymous
Hi there
ie.
assimb
thats fantastic thanks for all your help
assim
