HT-XF9000 New Firmware v1.847
typhoon9
Hi, Has anyone tried the new firmware for the HT-XF9000 and if so what are your thoughts on it ?
5 REPLIES 5
EdwinaU
Moderator
Hi Typhoon,
Hopefully some members will  get back to you soon with their experiences. Meanwhile, you can find out more about the firmware update here.
Best wishes,
Ed
BryanSimo182
I’m just about to download it. Really interested as I’ve just bout this with a 49X900F.
Does anyone one know if that TV supports eArc as want the streaming Apps to output Atmos etc.
Thanks and and sorry to hijack!!
typhoon9
Unfortunately my XF9000 developed a fault before i could do the update so i had to return it. They did not have another one in stock so ended up getting the HT-ZF9 Instead.
profile.country.SE.title
50nWyToMe
Yes i did update it , i took 20 minutes max   , and the overall experiece , it was a good update , better "air" in the sound now
HB
50nWyToMe
Sorry i refered to the Soundbar section .
