HT RT3 microphone connection
jemmah90
I have a audio technica lavalier mic which I need to attach to a HT RT3 for a work event.
When the mic is connected via the analog in on the back of the subwoofer, I'm not getting any audio out. Do I need an adaptor or a pre-amp, or is there a better way of connecting this?
Thanks!
1 REPLY 1
IamNic
Hi @jemmah90,
what kind of connector does your microphone have.
If it has a TRRS connector, it won't work anyways.
Depending on the mic, you probably need a pre-amp.
- Nic
