I have just bought the S370 and can't get it to show my PC files in the menus. I am running Vista and have tried Tversity and Mezzmo as servers. On Mezzmo I added the device by putting in the IP address and it said it was there (even showing the BDP's MAC address). I have checked all the network settings and the BDP is saying they are all ok. I have added files in Mezzmo but can't see them on the BDP. Any help would be greatly appreciated. Kev.
I could never get a PC/TVersity setup working with my S370 either. If you're using a PC to serve files, you might try the Servioo server that Catmambo seems to recommend to everyone. I havent tried it but it [allegedly] works ok with the S370. I stream to the S370 from a NAS device which has a TwonkyMedia server; you can get a PC version of Twonky too.
