.AVI Playback using RDR-DC205
profile.country.en_GB.title
Fubar2niner
Hi all.
I'm having a major problem getting any .avi file to play from dvd. Everytime I try I get a "File format not supported" message. Any clues anyone. I have tried burning discs from my computer in every way... ISO9660,Joliet,etc. I love my machine but this is bugging the hell out of me. Any help much appreciated.
Best regards.
Fubar2niner
profile.country.fr_FR.title
tandretion
Hi Fubar2niner
1) Make sure you have the lastest software v1.05 installed on your recorder (refer to the user manual to check it). If no, try to update to this last version (go to website, download the file, burn it on a CD following the details provided).
2) I also suggest you to re-encode your avi files into XVID. I have got this problem and encoding the concerned files into this format (even if the files are already encoded into this format) solved the issue.
Thanks
Tandretion.
4 REPLIES 4
tandretion
Hi Fubar2niner
Thanks
Tandretion.
Fubar2niner
Thanks for the reply and suggestions Tandretion.
I'll try both this weekend, as work is in the way atm.
Best regards.
Fubar2Niner
Fubar2niner
UPDATE
It worked !!!
Thanks very much Tandretion
Best regards.
Fubar2Niner
tandretion
You are welcome !
