Connecting CMT-ED1 to PC?
Raize.
Can anyone tell me whether it's possible to hook up this CD player to my PC with a cable so I can play music? Which cable type do I require?
The inputs/outputs can be seen here at 4:09 https://www.youtube.com/watch?v=CPZOMQXK6ds
Manual here: http://pdf.crse.com/manuals/3860292141.pdf
Almou_10
Specialist
Hi Raize,
I think this can be done by connecting a converter cable to the phono (IN) at the back of the CMT, and the other end of this cable converter should be 3.5 mm audio jack which will be connected to your PC.
hope this helps,
Almou_10
2 REPLIES 2
EdwinaU
Moderator
Hi Raize,
Welcome to the community.
We'll try to find some information for you and will let you know when we have an update. Meanwhile, maybe someone in the community will have some ideas about this.
Best wishes,
Ed
Almou_10
Specialist
Hi Raize,
hope this helps,
Almou_10
