Initial setup
Daviecaz66
Initial setup
On my sony bravia Can I select ok on initial set up without remote control
1 REPLY 1
profile.country.ES.title
HAL9000z
You don't have remote?? You'll need it to setup...
Some smartphones (most of the chinese brands) has got infrared blaster built-in... if you have one you can try it.
