HTS20R Speaker Extension Cable
Kcbhoy
Have recently bought a HTS20R surround sound, problem I have is that the cable for the small speakers are too short,  does anyone know if there is an extension cable available, I have phoned my local Sony shop who suggested that I cut the cable and put in my own extension, the current cable has a small push in plug which connects to the sub woofer, a cable with the plug and socket is what I’m looking for, any help would be appreciated
3 REPLIES 3
Joe_Dohn
Specialist
Sony only makes the original cables, so your best chance would be to check for your nearest store if they have Sony-compatible cables that are longer.
Kcbhoy
Thanks, have already spoken with local store , don’t supply and can’t help ,trying to source the plugs,sockets and pins so I can make my own
Joe_Dohn
Specialist
I suspected as much, sadly I can't help with those parts as I only know about this thread and I'm not quite certain these parts are available, but it's possibly worth a shot if you haven't checked it out already.
That said, it'd be really helpful to others if you share your findings here in the future.
- JD
